Old 10-23-2020, 08:57 AM
MODO Innovations's Avatar
Default 1968-72 Chevelle Door Lock Actuator Installation Kits
We are pleased to announce the release of more door lock actuator installation kits. These new kits are for 1968 and 1969-72 Chevelles. Like all of our actuator installation kits, these connect the actuator directly to the latch itself instead of the lock rod that exits through the top of the door panel. These kits were designed to work with our MI 700 Keyless Entry Kits. Each kit includes laser cut powder coated steel brackets, 304 stailess steel rods, mounting hardware and detailed installation instructions with templates.
Part number MI 940 fits 1968 Chevelles.
Part number MI 950 fits 1969-72 Chevelles.
Shannon
Modo Innovations
940-391-9002
Old 10-23-2020, 10:05 AM
camcojb camcojb is online now
So if you run this system, can the normal key lock be used also as a back up?
Old 10-23-2020, 01:58 PM
Absolutely. On all of our door lock installation kits the key lock cylinder is unaffected by the installation. They also work if you have shaved the door locks.
Shannon
Modo Innovations
940-391-9002
Old 10-23-2020, 03:34 PM
Thanks Shannon, I will be ordering one.
Old 10-25-2020, 06:53 PM
out2kayak out2kayak is offline
Any kits for '67 Chevelles?
-- Joe
Old 10-26-2020, 02:19 AM
Sorry, not at this time.
Shannon
Modo Innovations
940-391-9002
