					Originally Posted by dontlifttoshift  Cutting it out just leaves a sharp edge to rub on.  How bad does it rub?  Takes a bit of paint or changes lanes when you hit a bump?
 You could:
 Leave it
 Dial in more camber
 Hit the inner fender with a big hammer
 Buy wheels that fit
 8" wheel needs about 5" of backspace and 1* of negative camber if you want the car low and not rub on the outside.
 It’s rubbed a good amount of paint off. Going to drive it a little more and see how it goes. If i cut it I’m not going to just leave it open but build a little pocket and weld it closed. These wheels are 2-3 years temporary while I knock out an LS swap.
