Old 05-17-2022, 04:25 PM
DRJDVM's '69's Avatar
Default TO bearing issue
I swear to God my car is cursed....and people wonder why it's taken me so long to build my Cuda. I've had the transmission in/out going on 4 times now
The latest issue.... took the car to a local car show. Long line to get in so it was stop and go for a good 1/3 mile. By the time I got in, there was smoke under the car and it smelled like clutch.... bad..... couldn't really find the source but I thought I had overheated the clutch with stop and go.... its only got about 125 miles on a new McLeod twin disk. Got it parked and just hung out for the day. On leaving everything felt fine.... no more smoke, seemed to drive ok too.
Got the car home and next day got in up in air and there was fluid all over the bellhousing and the clutch master was down a good 3/4 inch. Looks like the TO puked fluid out the bell and the header, thus creating the smoke and smell.
So somehow I caused the TO to puke fluid... all I can think of is that I either didn't set the clutch pedal stop right and over extended the pedal a bunch of times in the stop and go traffic and blew the seal..... or I screwed up the TO to clutch air gap and over extended the bearing in some way.....
I must have checked both of those like 100 times.... but thats the only things I can think of to make a TO puke fluid
So.... all apart AGAIN.... TO bearing doesn't look jacked up ....Craig at Bowler had me send it back so they can inspect and rebuild
Clutch has some hot spots on the pressure plate so that's on the way back to McLeod to see if I ruined my $800 new clutch or it can be salvaged. Figured the hot spots are from the clutch slipping when the TO gave up and then wasn't fully releasing the disk
Any other ideas on how a TO would puke fluid? The lines are fine... so signs it rubbed a hole etc, so it must have come from the piston seal
This car has fought me this entire build.....
