Old 10-01-2006, 11:16 PM
ArisESQ ArisESQ is offline
Default heidts drop spindles
ive been seeing a lot of positive reviews on the ATS tall spindles that supposodely correct camber angle by raising the upper ball joint by an inch or so... well apparantly these heidts spindles do the same, and are considerably cheaper. so whats the overall consensus? good or bad?
http://www.heidts.com/heip41.htm
Old 10-02-2006, 12:26 AM
Do a search for a 2 inch pin drop and find out why they are bad on Camaros.
Tyler
Old 10-03-2006, 05:26 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default Spindle.
How much cheaper???
I saw SC&C's set up + ATS spindle for around 900$....Figuring a set of UCL are about 500$...it puts the spindle somewhere around 400$ (?Tyler) vs 300$ for the Heidts...
Guess i'd have to ask...
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 10-03-2006, 11:54 PM
Originally Posted by Leadfoot1
How much cheaper???
Lead.
and you also have to take into consideration that you would need a different set of front brakes, which is a pretty good chunk of change.
Old 10-04-2006, 06:09 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I suggest you do as Tyler suggested and do a search. I doubt you'll find any knowledgable poster who has good things to say about 2" drop spindles. Also, most of us who are looking for better handling from the front suspension of our first generation Camaros are also looking for better braking, so the brake swap, for us, doesn't really represent a cost increase. If you're only after the lowered look, and don't care about the other issues presented by the dropped spindles, by all means go ahead.
So to answer your question, no the Heidt's 2" drop spindles are a bad substitute for the ATS spindles for a performance use.
Old 10-04-2006, 09:56 AM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
I put a set of Fatman's G-force spindles on my Chevelle. They are also a taller drop spindle. They do drop down the steering arm to correct the bumpsteer. I have a set of 18 x 8.5's on the front and have not had any clearance problems. That is on a Chevelle though, the spindle is the same but the steering arm might be a bit different. Not sure.
Old 10-04-2006, 11:09 PM
some of us already have money invested in larger brakes on the stock spindles, so having to pay another $X,000 doesent really make much financial or logical sense. so like i said. it does represent a cost increase.
i wish they made those ATS spindles compatible with the aftermarket brakes i have now.
