Old 07-29-2007, 02:46 PM
Patrick's Avatar
Patrick Patrick is offline
Default Wheel Pro's Needed!!
I have a set of Boze Hi Octane wheels that I must run a 5/16 spacer on the front.
The spacer that Boze sent me is a generic aluminum spacer (the kind you see at any parts store...drilled to fit anything). The spacer has a ton of movement on the hub, so it is nearly impossible for me to have it centered when I tighten the wheel.
Here are my questions...
1) How much effect does the spacer not being centered have on wheel balance?
2) Does any one make a hub centric wheel spacer as small as 5/16"?
Old 07-29-2007, 05:03 PM
I gotta ya covered.
Frank Serafine
Old 07-29-2007, 05:11 PM
Patrick's Avatar
Thanks....I'll give you a call tomorrow.
