Old 12-08-2004, 12:21 PM
BC69's Avatar
BC69 BC69 is offline
Default Tach not working.
My car has an aftermarket covans dash insert, and autometer gauges. Lately the tach hasnt been working. All the other gauges are working just fine but the tach isnt budging. I think at one point when I turned the car on it would move over to the 0, but for the most part it remained 90 degrees down and nothing. I thought it might be a fuse, but all the other gauges are working. A little work had just been done recently on the transmission and starter, could anything have been knocked loose? Any ideas...another one of those simple problems that I havnt yet found the simple solution to.
Thanks Again
Tim
In memory of those gone before us
In gratitude for those who care.
Old 12-08-2004, 12:31 PM
MaxHarvard's Avatar
check the wire to the distributor. it should be green
Old 12-08-2004, 02:21 PM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
What ignition are your running? Stock, or an MSD?...MSD has it's own tach output, possibly loose, or perhaps someone forgot to replace the wire to the coil if you are running a stock type?
Old 12-08-2004, 04:25 PM
BC69's Avatar
Its stock, There might be a lose wire there, that be an idea.
thanks guys.
Tim
Old 03-15-2005, 05:59 PM
BC69's Avatar
Hey I am just bringing this back up cause I havn't solved this problem. I traced the wire to the distributor and tightened it, nothing...moved it around a few different times, and got nothing.
I have replaced some of the fuses, only one was really burnt out, but just tried anyway. Everything works fine except the tach and the gauge lights that come around each one...I dont get it. Is there a fuse connection in one of the wires?
Again, these are autometer gauges in the covans dash.
Tim
Old 03-15-2005, 06:14 PM
zbugger's Avatar
zbugger zbugger is offline
Can you describe how you have it wired in? It may be as simple as a bad connection to the red wire, or a bad ground. How do the connectors look? How does the rest of the stock harness look? Is the connection at the back of the tach good? How about at the connector for the stock to Covan's harness? It could be a lot of things, including a dead tach.
Old 03-15-2005, 07:15 PM
Keith's Avatar
Keith Keith is offline
I say bad ground...
There's nothing more common than unsucessful men with talent
GENESIS CHEVELLE
Old 03-15-2005, 09:47 PM
BC69's Avatar
Everything is brand new. I checked the connections to the back of the tach...it is good. The tach worked the first day I had that car, but then one of the times I started it, it was out!! (Only driven the car...5 times maybe) When you turn the key and all the gauges click into position, the tach will kinda click over, then come back to 90, so it seems to be getting something.
All the wires are new, I dont know the specifics of the setup, the orange wire goes right out the firewall to the distributor..the other just heads to the harness. I am sorry I dont have much more, but the guages are new, the wires are new...everything.
Thanks, hope it helps
Tim
Old 04-19-2005, 11:24 AM
BC69's Avatar
Okay this has been compounded more and I am lost. I followed the ground wires and dont see a problem there...no obvious sign of problem. But here is the deal, I dont have the tach, the gauge lights..parking lights, or tail lights. I have break lights, rear turn signals, and headlights. I have a feeling all these problems are connected, does anyone have a wiring diagram that would show this? It isnt a fuse, I have changed a couple recently and I know there are no blown fuses right now. I am just lost, and more concerned about the front parking/turn signals, and rear tail lights for some night driving than I am the tach...I just am really lost now.
So, TTT with this topic....thanks again in advance.
