View Poll Results: Which block would you choose?
Dart Aluminum Block 30 73.17%
World Product Motownlite 11 26.83%
Voters: 41. You may not vote on this poll
Old 12-18-2006, 07:34 PM
Fastbowtie Fastbowtie is offline
Smile Aluminum 427 Small Block Gen I
Ok, I have a question for those guys out there using a 427 SBC GEN I Block Iron or Aluminum. I am thinking about assembling an Aluminum 427 using either a Dart or World Block. This engine will be used as a daily driver and be taken on long trips, hopefully Power Tour. Can you guys give me some pros and cons to these blocks? I spoke with both tech departments and they both had good points to there products. The Dart seems to be the better block, however the Motownlite seems to be closer to a stock 400, which in the end could prove to be a better deal. The list kind of went like this.
Sorry Scott for the crude table.
.................................Dart............. ..........................Motownlite
Different Deck Heights....Yes.................................... ...No
Stock Oil Pan set up.......No (wide spread rail)................Yes....(Stock)
BBC Cam Core...............Yes............................ ...........No.....(Stock)
Stock Oil Filter..............No............................ ...........Yes.....(Stock)
Square Block................Yes.......................... .............No
Intake Height Stock.......No.................................... ....Yes....(Stock)
Stock Height Distributor..No................................... .....Yes....(Stock)
Special Head Studs........Yes.................................. .....No
Special Custom Cam.......Yes..................................... ..No Small Base Cir
Special Timing Gear........Yes................................... ....No
Weight.........................95 lbs...................................100 lbs
Billet Steel Splayed Mains.Yes......................................Yes
Material:.......................355-T6 aluminum....................357-T6 aluminum
Sleeve________________.250_______________________. 250" @ 4.155 bore
Raised Cam....................Yes........................ ..............No
Max Cubic Inch...............455 (4.185 x4.125)................434 (4.155 x 4.00)
Special Ribbing................No......................... ..............Yes
The thing that amazes me about these specs neither company thought about changing the lifter bores over to the new style (tall style) so you can use the new design lifters that are cheaper then the Retro Style lifters.
Please let me know your opinions and experiences. Thanks Guys!
Last edited by Fastbowtie; 12-18-2006 at 07:51 PM. Reason: Alignment issues with the table.
Old 12-18-2006, 07:43 PM
camcojb camcojb is online now
every machinist and engine builder I've met prefers the Dart blocks over the World stuff. Nicer machining, less casting flash, better quality, and on and on.
Old 12-18-2006, 07:54 PM
Yea Jody that's what I've heard too, but it seems like it needs everything. Oil pan, special cam, special head bolts, special push rods ect...
Old 12-18-2006, 07:56 PM
rocketman's Avatar
Of those 2 blocks a would recommend a Dart,my personal favorite is Donovan.
Keep your tolerance tight so when it warms up to operating temp it's not to loose and rattle to death.
Has long as it's a stock spec block,everything will bolt on it,usaully when getting into the tall deck blocks is when the cam tunnel gets raised and the spread the pan rail out.
Donovan makes(used to sure to be honest) block that will except all the stock hardware
Old 12-18-2006, 08:12 PM
Hows the pricing of the Donovans?
Old 12-18-2006, 10:29 PM
rocketman's Avatar
About the same 3k give or take.I haven't priced a standard block in awhile.
Old 12-18-2006, 10:34 PM
jonny51 jonny51 is offline
Have you considerd Brodix?
Old 12-19-2006, 02:40 AM
You know I haven't. I need to look at them too. I seem to forget there are more then just 2 companys making thoses things.
Old 12-19-2006, 07:58 AM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
Default Warhawk
Does it have to be Gen I?
World makes an aluminum LS series block called the Warhawk that accepts a 4.125" bore and costs less than the Gen I blocks. About $2K - $2500
Sorry, I confused the World aluminum block w/ GMPP's iron block. The World Block is $4K. Forget I was here.
Mal
Old 12-19-2006, 10:18 AM
The more I read on the net about aluminum the less I like it. I still want a SBC 427 though.
