Remote resevoir questions
Im building my own remote resevoir tank and need a little info.
How much fluid should it hold? Im running a cooler if that makes a diff.
Are the after market tanks vented? If so how? A simple hole or a pop off afair like a rad cap.
What I have so far holds about 9 1/2 OZ about the same as the Zoops in dimention I can make a tandem tank to double this if nessisary. Mine Is baffled also
Thanks guys.
**********************I just measured my stock p pump tank and it holds 10 OZ*********** I also just found a 32 OZ alternative that will use my baffles.
