This is my To do List. Will Probably edit many times:
Mechanical:
Finish Installing LS1 accessories
Mount PCM and wire engine up
Install T56 clutch master and pedal assembly
Install interior shifter for T56
Purchase and install FI gas tank and run gas lines
Re-flash PCM
Install 99 mustang Hydro-boost master and booster (got the idea from here
http://www.geocities.com/casanoc/)
Install LS1 brakes on rear 10 bolt using bracket kit
Run all brake lines
Purchase and Install 4-link (Either DSE or Chris Alston G-Bar)
Shorten and install LS1 aluminum drive shaft
Install 4th gen radiator and fan assembly
Figure and purchase wheels / tires
Install correct flaming river mounting bracket and horn adapter on steering column
Purchase and install new steering wheel
Purchase and install new front light harness
Purchase and install Vintage air A/C system
Purchase and install new battery
Purchase and install headers, x pipe and dual exhaust
Rebuild 12 bolt for later install
Body:
Install New convertible top
Purchase and Replace passenger and driver rear quarter
Install DSE Mini-tub kit
Purchase and install deck lid
Purchase and install DSE sub frame connectors
Purchase and install complete front assembly (hood, inner and outer fenders,etc, have nose assembly)
Purchase and install tail panel
Purchaser install chrome trim and window lace material
Install new antenna
Install passenger and driver mirrors
Purchase and install emblems
Install insulation
Install carpet
Align Body panels
Prime Car
Other:
Purchase and Install Power window kit
Alarm
Digital dash
