Old 08-16-2007, 02:45 PM
markss28 markss28 is offline
Default converting 2 bolt to 4 bolt
I have a 2 bolt in my car right now and I have all the parts to build a new 383 stroker with crank , rods, pistons and all. All I need is a 4 bolt but they seem to be very hard to find or a bit pricey. I have seen on line a few engines converted to a 4 bolt and was wondering if that was a good option.
Will it have the same stregth as a 4 bolt or just a bit stronger then a 2 bolt?
Never Stay Stock
Old 08-16-2007, 03:28 PM
QSPres QSPres is offline
Banned
2 bolt blocks are stronger. They just have less clamping force on the crank.
I say "F" the four bolt blocks. Buy a set of splayed main caps and have your machine shop drill and tap your block for them. I did that to several Pontiac motors and they all ran great.
Old 08-16-2007, 06:54 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Splayed caps on a stock 2-bolt block is the way to go. The 2-bolt blocks have much thicker webbing than the 4-bolt blocks.
Old 08-17-2007, 06:14 AM
I heard that same thing years ago and just wanted to confirm it. I will be checking with the machine shop to see what it would cost.
Never Stay Stock
Old 08-19-2007, 03:48 PM
2muchTA's Avatar
2muchTA 2muchTA is offline
I converted my 2 bolt to a 4 bolt with splayed caps. I couldn't be happier that I did it.
For comparison... I had my block cleaned, the caps installed (plus the price of the caps) and new cam bearings pressed in and it cost me just shy of $700. I don't know if I payed too much or too little but it's a starting point.
"Nothing's more American than that" ... "How's about a big ol red, white, and blue speadboat driving down a river of monay."
The projects from hell:
94 GMC Yukon - The new (to me) tow vehicle
85 TA - The "race" car
82 Firebird SE- tha heap
66 Mustang - 4bbl 289 With power brakes. It's a classic, what more do you want.
Old 08-27-2007, 07:02 PM
cj422man cj422man is offline
Hey guys im a newbe here and thought i would let you know that i had my 400 converted to Eagle splayed mains, Moroso filler up to the plugs, new cam bearings, alignd bored and honed, and clearanced for 3.875 crank, plus the main caps and it was cnc done plus painted and cost me $510. 4 bolt 400 blocks are the weak ones not the 350. if 350 4 bolt were weak then they wouldnt have been in trucks. i own 6 350 4 bolts and 1 2 bolt also 2 283 blocks and 2 305's want to buy any??? if you would like some pics of the main caps installed shoot me an email i have a lot of pics of mine. and i can scan a copy of my bill for the 400. check out www.rmcengine.com for the videos of the cnc machines. mine was done on the V30. go to www.montecarloss.com/SSThunder/SBCinfo.html and at the bottom of the page it gives hp recommendations for each block. im not trying to step on any toes, just my 2 cents. thanks
Old 09-16-2007, 05:08 PM
here is my 400
Old 09-18-2007, 10:22 PM
crazycarl's Avatar
crazycarl crazycarl is offline
Do the two bolt block and have it machined for the splayed four bolt caps. The caps aren't necessarily stronger, they just flex less. Think about it, the more holes you have in something, the weaker it is, but the less points you have holding something down, like a crank, the more it will flex. A splayed cap spreads the stress of the spinning crank over a wider surface area giving you the best combination possible.
I'm probably just screwing with you, so please don't take it personal.
Old 09-25-2007, 11:17 AM
Thanks for the info, but I found a 4 bolt bored and stroked it and am not assembling the engine.
Never Stay Stock
Old 10-07-2007, 03:40 PM
rocketman's Avatar
Splayed is the only way to go when doing a convertion
