Old 12-29-2007, 06:25 PM
bucks69 bucks69 is offline
Default Ideal front wheel backspacing for a GENI
Hey guys if you were building your "ideal" road/street racer what would be the backspacing you would want on the front with a 17"x10" wheel And also an 18"X10" wheel? Also to go a little further what would the rear backspacing be for a 18"x12 and a 19"x12"? This is assuming you were going with a custom frame and could go with whatever size and backspacing you want. This is for a regularly driven street car if that helps any. Also please elaborate a little about your decisions please. Thanks in advance.
Old 12-29-2007, 10:50 PM
DriverzInc DriverzInc is offline
Well, ideally, you would want to have a 0 offset on both wheels. Keeping things centered puts less stress on bearings and such. Ask any mechanical engineer, they'll tell you the same.
Old 12-30-2007, 06:23 AM
This could quickly turn into a huge technical discussion on suspension. But, short story, since longer is better for suspension arms, you would end up with a big possitive offset on your front wheels to make your suspension design better. But for looks most do not like the high positive offset wheels and want some "lip" on the wheel.
On a live axle rear it does not matter.
Frank Serafine
Old 12-30-2007, 08:07 AM
Thanks Jon and Frank. I appreciate the reply. So as far as looks go(performance second hand) what would be the suggested backspacing that you would consider when you would be doing your own car. This has been my brickwall on ordering stuff and I know I am overthinking this I just dont want to be wrong this early in...LOL
Thanks again
Old 12-30-2007, 08:16 AM
It depends. I am assuming you are mini tub? So we usually do a 6 to 6.25 backspace. Although I did buy a dozen custom 19" outer rims shells to be able to do a 6" lip on Lisa's Project EmptyNest which is right at 5" backspace or so. Looks KILLER! On the front, a 8" rim with 4 3/4 backspace is usually good on stock track width and give a nice 2" lip. Again, though if you are designing the front suspension from scratch, you would want to make the arms as long as possible, changing you backspace. Brake caliper clearance also will be a dictator here.
If you would like to talk through this you are welcome to call
four zero seven 832 1752
8 AM to 10 PM
Frank Serafine
Old 12-30-2007, 08:29 PM
Frank I will call tomorrow if you are open. And yes front track width is whatever I want it to be so I just need to know what a decent backspacing would be. I need that info to order, I also have to account for brakes and what that would do to the width needed. Thanks again
