Old 05-08-2008, 01:49 PM
dplenzig's Avatar
dplenzig dplenzig is offline
Default Threading fuel rail
Anyone know what type of tap is used to thread 6an on blank fuel rails?
Daren
69 Camaro
DSE subframe & Quadralink
Aluminum 406 Twin turbo
TKO 600
Old 05-08-2008, 03:04 PM
I would think you could use a pitch gauge like with a normal tap. Probabaly a good idea to call whoevers AN fittings you plan to use. Earls, russell, etc.
Old 05-08-2008, 03:57 PM
most come in an AN thread, like #6 or #8. If you do that, you need a chamfer at the end for the o-ring to seal against. I have also seen them done in pipe thread, with sealer on the threads.
Old 05-08-2008, 07:00 PM
projectile's Avatar
projectile projectile is offline
#6 an should be a 9/16 thread with 18 threads per inch. Like Jody said you need a champher if you are going to use an o-ring. I think you can also buy a cutter that will properly machine an o-ring receiver. I did mine in a lathe. I did a counterbore with a light champher just to start the o-ring.
Ray
Old 05-09-2008, 04:35 PM
badmatt's Avatar
badmatt badmatt is offline
An A/N thread is just a regular strait thread.
