Old 07-31-2008, 03:53 PM
67ragtp 67ragtp is offline
Default LS builders
Need suggestions what companys are building quality LS engines. I want 427 cuin. and prefer to avoid the dry sump system. I would like to keep it at or under 15k and hopefully that includes the ecu. 500 rear wheel hp is the goal. Is my budget short, can this be done?
BTW- I called Katech, 427 re-sleeved block 427 heads and katech torquer cam, 427 intake with injectors , 19k no ECU,no flywheel,no accessories. Too rich for me, these guys must be the best of the best.
Anyway if you guys can suggest a builder, reliability and good street manners a must- Thanks Rich
