Old 03-25-2010, 01:49 PM
Smitty67 Smitty67 is offline
Default Marquez Door and Quarter Panel kits
Can someone tell me if there is a difference in the Door and Quarter panel kits between 67 and 68 Camaro? If so, what is the difference?
Old 03-25-2010, 03:01 PM
130fe 130fe is online now
Post
For the fronts, the 67's have the metal piece on the top part of the panel (part of the door) and are only about 3/4 the length of the 68/69's. I assume you have a 67, so here is a picture of a 68/69 style- http://home.coqui.net/borench/images/interiors_01.jpg
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-25-2010, 04:08 PM
Thanks Chris,
On the stock door panels, I understand the 67 has the upper metal exposed while it is covered on the 68 and 69.. Is the same true with the Marquez panels? I assumed the Marquez panel would cover the top metal on the 67 door as it does with the 68 and 69 as I haven't seen a picture of a Marquez panel that does not cover the entire door.
Old 03-25-2010, 04:28 PM
Thumbs up
Smitty, Danny Thomas had some put on his 67 (Black Pearl) by Frank @ Prodigy (I think). Here are some pictures- http://musclerides.com/forum2/showth...ht=black+pearl Maybe try and call Frank and he could give some insight on the install.
Chris
1968 Camaro SS
LS3/T56
Old 03-25-2010, 06:42 PM
Thanks Chris
Old 03-25-2010, 08:52 PM
CG3D's Avatar
CG3D CG3D is offline
There really is no difference aesthetically, as others mentioned, there is a difference on the door shell inside.
We cover this with a slight modification to the back side of a '68 panel for a '67 door. It ends up looking the same as a 68 panel.
We actually did two of these this week.
Chris
