Old 06-12-2019, 11:53 AM
SRD Art's Avatar
SRD Art SRD Art is offline
Default Pro Touring S10 - "Quicksand"
Some of you know that my son and I are G-body wagon guys. We also like S10s, and as we're building our wagons to be more than daily drivers we both picked up an S10 to putt around town in. Mine is an 88 Blazer, click here for a couple pics. My son picked up a beater '84 pickup that will be his first ground up build, doing almost all the mechanical, body and paint work himself.
The set up is: Engine is a 355 with Scat rods KB 10.5:1 pistons, a .540" roller cam and Engine Quest circle track heads topped by an air gap dual plane and 750 Holley. Trans is a T-56 6 speed from an LT Camaro. Suspension is DJM drop spindles, 700# drop springs, Belltech shocks, Belltech 3" drop leafs and 4" blocks. C5 Corvette 13" brakes on UMI brake adapter brackets are wrapped by 18x9 XXR wheels and 275-35 Nitto NT555s all the way around. Coming soon is a disc 8.8" Ford rear axle swap and more UMI suspension upgrades for better handling. 👍
Here's a few pics of where he's at with it. More coming soon!
1. I did a rendering for him when we started the project to give him some guidance and motivation. He'll be using late model Toyota truck tan and the hood louver is from a late model Camaro.
2 & 3. Mocking up for hood mods.
4. The truck should be somewhere around 3000-3200 lbs so the 13" "budget" C5 brakes should help it stop real well.
-Ben, Your friendly neighborhood Rendering dude, PM me for info!
My SRD Renderings Instagram page
My SRD Renderings Facebook Page
Pumkinator '79 Cutlass Wagon Build
The Following User Says Thank You to SRD Art For This Useful Post:
rixtrix1 (06-12-2019)
Old 06-13-2019, 05:40 AM
Roscoe03 Roscoe03 is offline
This will be awesome! What better way to bond between father and son.
Old 06-13-2019, 06:41 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Pretty sure G body tubular control arms bolt right on to an s10 if I remember right.
Instagram- camaroaj
Old 06-13-2019, 09:29 AM
SRD Art's Avatar
Thanks Roscoe, and yeah it is.
You are correct AJ, aside from the steering linkage because the S10 is narrower G-body front suspension is a direct bolt in for S10s.
Old 06-13-2019, 10:01 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Lower arm bolts on S10's are 1/2", I believe, and G-bodies are 12MM, so you have to make sure you have the correct inner sleeve. I haven't changed my lower arms on my truck to aftermarket, never bothered to check the size and just used a die grinder to slot the holes when I relocated the rear mounting point for more caster and to center the wheel in the fender better. These are really neat projects, Ben and Roman!
Ben, did you know that Speedway Motors, Lincoln , NE, offers a G-body centerlink that's supposed to help with the inherent bumpsteer problem with these cars? The inner tie rod end mounting points have been moved. I haven't investigated it as it fits nothing I own, but the theory is solid and probably is safer than welding new mounting points onto an existing center link.
Ric
Old 06-14-2019, 09:34 AM
SRD Art's Avatar
Thanks for the input!
Old 09-08-2019, 07:07 PM
syborg tt's Avatar
I am in love and can't wait to see more.
marty-mj
Old 09-09-2019, 06:35 AM
SRD Art's Avatar
Thanks Marty!
We've had a problem with the heads and after doing lots and lots of internet research and talking to different engine builders and circle track racers that often use these heads still no answers. What a headache it's been dealing with a problem no one has ever dealt with before. We even sent them back to the engine builder we bought them from. After inspecting them he was convinced our Comp rocker arms were defective, despite them working fine on other heads we have, and he sent the heads back saying use a different rocker. I finally had a great conversation with Judson Massingill, the director of the Texas based School of Automotive Machinists and engine masters top 5 competitor. He confirmed what I had thought, the rocker stud mounts are machined in the wrong location- closer to the valve than they should be, making it impossible to get decent rocker arm geometry. Since the distributor we got them from wouldn't warranty them our only option was take them to a local machine shop and have the stud bosses machined shorter and we'll have to run a pretty short push rod so to get the rocker tips to line up on the middle of the valve tip. Although the geometry is off Judson and our local machinist assured us for what the engine will be used for and the cam and rpm range it'll see there wouldn't be any issues with doing this.
Roman's getting close with the rest of the truck's repairs and upgrades and we're anticipating getting the heads back from the machine shop this week so we're hoping by the end of the month it'll be back on the road. More coming soon...
Old 09-09-2019, 08:43 AM
ScotI ScotI is offline
This should be a cool project as it's hard not to like a square S10.
Where did you source the 700# drop springs? How much was the 'advertised' drop?
Old 09-09-2019, 09:28 AM
SRD Art's Avatar
Thanks Scot, he's getting pretty close to having it running now, hopefully by the end of the month. We ordered a set of Moog 5662 Coil springs from Summit, listed on Moog's website as 748 lb. spring rate. He cut off 1.5 coils which is what the average that most S10 guys were doing. That theoretically will increase rate even more but we just say 700 lb. to keep it simple. Right now the truck is maybe 1/2-1" higher than what we're after but we need to drive it a bit to let things settle and then we'll asses how we like the ride height again.
BTW these same springs work in a G-Body, I have them in one of our cars with 3/4 coil cut off to yield about 2 1/2" drop.
