Old 05-10-2010, 10:33 AM
AAW's Avatar
AAW AAW is offline
Supporting Vendor
Thumbs up American Autowire - New headlight solutions!
Three new headlight products! Switch between high and low beams, automatically reset to low beams, and flash to pass!
Coming early June 2010
Watch the video!
In the above video, Michael Manning, president of American Autowire discusses and installs three new headlight products.
Latching Relay Module (510170) replaces a dimmer switch and allows you to switch between high and low beams with momentary switch on steering column using either a turn signal switch (510169) or a tilt lever switch (510168).
In addition the switching between high and low beams, the latching relay module automatically resets your headlights to the low beam position whenever the headlight switch or vehicle is turned off. Lastly, the latching relay module allows you to flash your high beams in a "flash to pass" situation, when the headlight switch is not in the on position.
Michael explains "What is a momentary switch and why use it?" He then shows the difference between the installations on a plastic-body turn signal switch (adding an additional ground wire) and a tilt lever switch (already grounded). Finally, Michael installs the latching relay module by removing the dimmer switch, connecting the low and high beam circuits, and testing the results.
Old 05-14-2010, 07:14 AM
PRRC PRRC is offline
That's a very nice set up. The street rod guys will love you. With so little room on the floor for a regular dimmer switch this will be a great option.
Tim
www.paradise-road.com
