Old 07-23-2010, 08:37 AM
Jay Hilliard's Avatar
Default which subframe connector
I dont want to cut the floorpan on my wifes 69 project so I have looked at the Hotchkis connector and the Global West connector. Any pro's/con's to those?
Do they tuck up to floorpan nicely or hang down to far?
Anyone have pics?
thanks!
Jay
Old 07-23-2010, 09:23 AM
Hotchkis all the way. They are notched to form fit you floor.
Frank Serafine
Old 07-23-2010, 09:24 AM
Musclerodz's Avatar
Hotchkis
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-23-2010, 09:54 AM
Thanks Frank and Mike.
Jay
Old 07-23-2010, 11:15 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I have the Global West ones and they fit pretty good and I'm not unhappy with them, but yes, the newer Hotchkis ones look like a better fit.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 08-04-2010, 12:13 PM
Hotchkis Hotchkis is offline
senior member
Thank you to everyone in this thread.
We worked extra hard on our subframe connectors to make sure they give our customers the most clearance and the best performance.
We always recommend welding in subframe connectors towards the end of the build. Ours are designed so you can bolt them in if absolutely necessary, but for maximum strength it's best to weld the bolt holes and if you're committed do a small perimeter weld around the front and rear backets. Because the welding is minimal and there is no cutting or relocating required, Hotchkis subframe installation is easily done on a freshly finished car. As for when to install exactly...how about "before the first burnouts"?
Many of our customers have had luck with Muffler shops doing the install. Just remember that it's critical that the rack they use is a drive-on rack where the car sits on the wheels with its full weight. Lifts that pick the car up by the frame don't work as the frame will not be settled correctly.
Old 08-04-2010, 01:39 PM
130fe 130fe is offline
Thumbs up
I agree with Chris (I have the GW ones also). If I did it over again I would get the hotchkis ones.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-04-2010, 04:42 PM
EBMC's Avatar
EBMC EBMC is offline
We use only the hotchkis ones as well.Very good fit.
Steve Keefer
Old 02-27-2011, 02:18 PM
fastlaners fastlaners is offline
Default Ideas on install of subconnectors
Hi; listening to install suggestions; it shows a four post style lift with tires on lift plates; to keep car on wheels/suspension during install. I have a two post lift with swinging-style arms; does anyone have any ideas on utilizing this style lift to do job? maybe some how spaning rockers; say maybe 2x4s on lift pads; to spread weight evenly on rocker lift points? the engine and interior is out of car so it is somewhat lighter. thanks Johns
Old 02-27-2011, 02:51 PM
Sieg's Avatar
Sieg Sieg is offline
As I read it the weight has to be supposed on the wheels. Your two post will create alignment issues/challenges.
