Old 11-26-2016, 09:57 PM
Default 7" LED headlight
Anyone ever run these? In particular want to know if the fit in the bucket (67 camaro) looks like the newest model doesn't need a built in fan. Vendor thinks they should work but they are really VW guys and have never personally fit them in a GM
https://vintagecarleds.com/
Old 11-27-2016, 10:35 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Looks like a good product. The rear of the bulb housing doesn't look overly large. I don't really see anything about the wiring, if it has to be spliced or are factory plugs going to work?
Old 11-27-2016, 12:23 PM
Factory plug and they only draw 2.5 amps the newest ones use silicon and don't need the built in fan ... here is a video the vendor sent me
https://youtu.be/Azcfhf2hQB8
Old 11-27-2016, 02:03 PM
rallystyle rallystyle is offline
they look like a aftermarket housing with plug n play led setup in them. you will get lots of foreground light and loose distance lighting. i would look at trucklites or something else . watch
https://www.youtube.com/watch?v=XNZT6QqHHOo
1970 El camino
1969 camaro
1996 civic
Old 11-28-2016, 01:48 AM
Stielow has run the trucklites in his builds, Mayhem at least, so there's that.
Old 11-28-2016, 10:19 AM
Another vote for trucklites, I have them and they're awesome!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 11-28-2016, 10:57 AM
Do they fit in the stock buckets?
Old 11-28-2016, 12:00 PM
The research I've read is that they stick out 1/4 to 1/2" vs stock but fit snug and many leave it that way as they say they cannot tell. Others trim the buckets a bit.
Old 11-28-2016, 12:22 PM
Mine seem to fit just fine. By bucket do you mean the stainless retainer or the plastic part of the grille (the bezel)?
Been a while since i've had a stock light in mine, but I can snap some photos if you want. No bezel on just yet through, need more test fitting (touching grille a bit in areas and hard to screw in), then need painting.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 11-28-2016, 04:06 PM
Here is one of the more detailed posts I saw of someone who installed.
http://www.pro-touring.com/threads/1...79#post1065479
