Old 08-09-2011, 02:08 PM
FadedSS FadedSS is offline
Default Recommend Booster/MC
Hey guys, I am running c6z06 front brakes and stock rear drums on my 73 Camaro.
I’d like to continue running power brakes and need a new booster/master. Can you recommend me a booster/master that will work with my application?
I did buy a 10psi residual pressure valve to run the stock drums until I swap the rear and upgrade the brakes…
Thanks!
Old 08-09-2011, 02:57 PM
Musclerodz's Avatar
Thanks!
why the residual valves? It does not need it. 1" bore master and a 9" dual will do wonders.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-09-2011, 06:53 PM
thanks for the response. i really appreciate it as i am a noob when it comes to brakes.
i was told when i ordered my brakes that the residual valve would be necessary to run the stock drums.
i purchased a wilwood 1" mc. will a 79 trans am dual 9" booster bolt right up?
Old 08-10-2011, 12:26 PM
Musclerodz's Avatar
yes, make sure you install the bullet in the wilwood master if you use the late booster with short rod
Mike Redpath
facebook page
Old 08-10-2011, 01:47 PM
cool, thanks a lot buddy. appreciate the help!
