Old 05-14-2010, 07:13 PM
Saleen04 Saleen04 is offline
Default 06 GTO front and rear seats in a 70 Chevelle....help needed
I just picked up a set of front and back GTO seats for my 70 Chevelle to replace the bench.
How do the fronts mount to the floor? Which holes do you line them up with and how what is the best way of making new holes to accomodate the seats?
How would you make the power seats work?
How would you go about widening the back seats to make them fit?
What has everyone done for the seatbelts?
Thanks for all the help as I would rather going into the install with more koweledge.
Old 05-16-2010, 04:32 PM
Anyone?
Old 05-16-2010, 04:37 PM
dhutton dhutton is offline
You might have better luck over on a Chevelle forum or maybe on performanceyears.com forum to see if anyone has mounted them in a GTO.
Old 05-16-2010, 07:08 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Set the front seats in your car and see where you the most comfortable, Take your measurements and start fabbing brackets to meet the original holes or make new ones.Keep checking to make sure your square and level. As far as the back seat ...You will have to take cover off and widen frame and foam on the center then have someone sew a new cover
TRACY WEAVER
www.recoveryroominteriors.com
Old 05-17-2010, 08:37 PM
Thanks for the advice!
Old 02-10-2011, 07:34 PM
ssick chevelle ssick chevelle is offline
any updates on this? id really love to do the same as i found a cheap back seat for an 05 gto
Old 02-11-2011, 03:15 PM
brans72 brans72 is offline
You can find info on chevelles.com and pro-touring.com
Old 02-12-2011, 06:20 AM
TheShopLLC.com TheShopLLC.com is offline
Default 65 Gto With 06 Gto Seats
This might help out guys, here's a 65 GTO with front and rear 06 GTO buckets that have been modified, custom brackets and shortening of the cushions...... Forms are made for fiberglass which will later be removed.... http://www.hubgarage.com/mygarage
www.theshopllc.com
TheShopLLC.com
Old 08-06-2011, 05:30 AM
lemans70 lemans70 is offline
I am trying to do the same thing to my 70lemans. I would like to put bucket seats in the rear and the front and then build a custom console to go from the front under the dash all the way to the rear. My question is does anyone have the dimensions needed for the seats in the rear i.e. can the rear buckets simply be a set of front buckets without modification? or do they have to be cut?
Old 08-30-2011, 06:05 AM
WE TOOK A SECTION OUT OF OUR REARS SO THAT THEY DIDNT SIT UP HIGHER THAN THE FRONTS, OUR HEIGHTS BETWEEN FRONT AND REAR ARE THE SAME....WE'VE ASLO GOT A CONSOLE GOING FROM FRONT TO BACK WITH A VERY TRICK SET UP WITH THE PACKAGE TRAY......WILL POST MORE PICS ON THIS IN A COUPLE OF WEEKS.....AS FAR AS DEMENSIONS GO, BUST OUT THE TAPE MEASURE AND TAKE YOUR TIME BEFORE YOU CHOP IT UP......AND DON'T FORGET ABOUT COMFORT.... GOOD LUCK
http://www.facebook.com/#!/pages/The...03853559705438
www.hubgarage.com/mygarage/CLINT
TheShopLLC.com
