Old 02-17-2011, 07:31 PM
coolwelder62's Avatar
Default Cut to fit weld in C-6 frt. clip for 64-72 Chevelle's
C-6 suspension for 64-72 chevelle's. I have been working on drawings and design for a cut to fit weld in C-6 corvette frt clip.I need a donor chevelle chassis.If I can find the right lateral-g member I will do the labor at N/C.Cost of the clip w/ splined sway bar,bolt on steering arms,and machine work on spindles would be $1,650.00.Owner would need to supply C-6 componets,Rack & pinion,coil over shocks.I will also sell new C-6 componets at my cost if the owner want's new c6 componets.Please contact me at my shop 1-785-594-7481 during the day.Thanks Scott.
Old 02-19-2011, 07:20 PM
okyankee okyankee is offline
i got a 65 chevelle frame taking up space in my garage. it has my body shell on it that i would need to move to my other frame. i could get pics of it then. i got the project off a friend and he said the frame was never hit but i can check that when i move the body. i would send some pics then. i would let you have it if you come and get it in exhange for a discount on a future mini tub or something. i realy need the space and i am not worried about making money on it. let me know if that sounds good. i am in yukon, ok btw. shoot me a message if interested.
Old 02-19-2011, 07:55 PM
Thank's, I have picked up a 66 chevelle chassis.I will be working on it in the next few month's.Then I will have a frt.clip that chevelle owners will be able to cut off the OEM frt.suspension and weld right on to the stock frame and have late model C-6 corvette componets.The frt clip should sell for about $1850.00 bare w/steering arms and sway bar kit.The owner can pick a rack,shocks,and c6 pcs. on his own.Or I will supply new gm componets.Then I have plans for a tri 5 weld on clip.Thanks Scott
Old 02-26-2011, 01:17 PM
clu269's Avatar
clu269 clu269 is offline
How far out are you on this project? Would you be interested in building a clip around AFX spindles with speed tech upper and lowers?
Old 09-27-2011, 05:33 AM
C5 Longroof's Avatar
C5 Longroof C5 Longroof is offline
Any updates on this killer project?
I tried to C4 my '67 Chevelle 2 Door Wagon, but there really is just too much suspension knowledge that I am lacking...Would love to see a final product here..
Rick
Old 09-28-2011, 01:10 PM
PASD U PASD U is offline
Interesting.
