Old 12-02-2011, 03:50 AM
oldgoat's Avatar
oldgoat oldgoat is offline
Default GM A body rear coil overs?
Anyone done one of these. I am in the middle of prototyping a setup similar to the Global West concept. Has anyone used this kit or another? How about real world results.
Old 12-02-2011, 04:40 AM
Supporting Vendor
Our 66 Chevelle mule has been equipped with either Shockwaves or coil overs for quite a while.
We use a bolt-in bracket in the stock shock location so your exhaust and lower control arm mounted sway bar will still work. The upper mount is a bolt-in adapter that allows you to utilize the bearing mount of the shock.
You can see it here:
http://www.ridetech.com/store/suspen...djustable.html
I've also attached a quick image for reference.
Skunk Werks
Ridetech
www.ridetech.com
Old 12-10-2011, 08:27 AM
rallye455 rallye455 is offline
Do you sell just the bolt in brackets?
Old 12-11-2011, 07:13 AM
Supporting Vendor
At this time you have to buy either Shockwaves or Coil-overs to go with the brackets as the length of the shock is designed into the bracket. So if you were to buy our bracket, then use a shock different than what we use, the geometry would be off and therefore not as affective as the kit we designed.
Sorry.
Skunk Werks
Ridetech
www.ridetech.com
