Old 02-08-2013, 07:22 PM
tt69camaro tt69camaro is offline
Default 70 Chevelle with 305/45r18's
I just placed and order. Rears= 9.5" rim with a 5" BS and 305/45r18's. Fronts= 8" rim with a 4.5" BS and 245/45r18 tires. I would also like to drop the car an inch or two. Will I have a problem with rubbing front or rear?
Old 02-08-2013, 08:05 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I don't think it'll rub. It will be cutting it close at a 2" drop though. At 1", you'll be fine. I had 245/40/18 which is a shorter tire and didn't have a problem. I doubt very seriously the rear will rub because I had 305/30/20 with a 6" backspacing and it didn't rub.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-09-2013, 05:41 AM
I know people are running the rear combo with 5.5" BS and it works but the rim I chose (Boss 338) only came in a 5.03 BS. What size rim width did your 20's have?
Old 02-09-2013, 12:57 PM
barrrf's Avatar
barrrf barrrf is offline
You can always run a 1/2" spacer if need be. Also the rear fender lip is rollable for clearance if necessary.
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 02-09-2013, 03:04 PM
I wouldn't want a spacer. My concern is that it will be to close to the fender. I don't mind rolling the fender more if needed. I measured the face of the drum to the inside and outside of the wheelwell. The inside measured 7-5/16" and the outside measured 6-7/8" to the rolled lip. My calculations say it will work but the majority of people go with 5.5" BS. I just don't want to get the new wheels here and they won t fit!
Old 02-11-2013, 05:21 PM
I cancelled the rim order and going with a different wheel with a 5.5 bs. I just didn't want to take the chance. Anyone run this tire combo? If so, how much can you lower your car? 0,1 or 2 inches?
Old 02-12-2013, 03:56 AM
mild2wild mild2wild is offline
I have a 70 GSX replica with 19X10.5(6.5 BS) rear ZX3R with 295 tire, and front 245 on 18X8(4.75 BS). Complete Ridetech air suspension, no rub. This should be a pretty good spec, but each car may be different.
Old 02-12-2013, 10:06 AM
214Chevy's Avatar
.....What size rim width did your 20's have?
I had 20x11's.
'68 C10 swb
'72 Chevelle
Old 02-12-2013, 03:19 PM
71OLDS's Avatar
71OLDS 71OLDS is offline
I'm running 255/45/18 fronts on 18x8 and 305/45/18s on 18x10. Can't speak for a Chevelle but on my 71 442 on the rear stock spring height is perfect for the 28.8" tire. Front is lowered about an inch with my coil overs. Now I also like the sidewall to show (with my RWL) and I like having enough ground clearance with my headers to drive over speed bumps and basically be safe for all street driving. If you like the lowered look (usually you would have a smaller sidewall - like a 35 series) and you don't mind having less ground clearance, you could go an inch or two lower on both the front & rear.
My old 18" rims with the same size tires, and STOCK size rotors and fornt end had a BS that was 4.5 and 5.5 for the 8" & 10" wheels respectively But.....when I put on the B body spindles and 13" rotors on the front and 12" rotors on the back it pushed everything out. New BS for the new wheels is 5.25 front and 6 rear. My old wheels would NOT fit with the new spindles and rotors. Something to consider if you haven't done that yet and are considering it. I had to roll the rear wheel well lips too. Here are some pics:
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
Old 02-15-2013, 03:55 AM
The stance looks good on your Olds. Are those your original springs?
