Old 01-10-2013, 05:53 AM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default 69 Camaro gauge packages from NVU
New gauge kits and mounting solutions for 69 Camaro from NVU
Our exclusive molded mounting kit installs any of our 4-3/8" gauges into the factory 69 Camaro dash openings. The design makes the installation look like it came from the factory. Click the pics for a closer look.
Molded and CNC cut pockets that fit into the stock dash for a factory installed look. Install ant New Vintage 4-3/8" gauges. You can use a 2 gauge set, or our 4-3/8" speedo and tach, mounting the minor gauges in the console, its up to you.
PART NO 88690-09 69 CAMARO MOUNTING POD KIT
Below Left: Kit includes Left and Right mounting pods, brackets and detailed instructions. Requires trimming clearance on the back of the dash not visible when installed. Below Right: Gauges fit tightly in bezel and is compressed against the factory dash opening for a great fit.
Below:
Just a few examples of how you can set up the dash to fit the theme of your car. Select the gauge style and layout that suits your build. 3-in-1 gauge kits have all the functions you need right in front of you in a 2-gauge kit. Speedo, tach, fuel (0-90 GM match) temperature, oil pressure and voltage. All 3-1 kits include turn signals, high beam and warning lamps, integrated right into the gauge. For a more traditional setup, run a 4-3/8” speedo and tach with minor gauges in the console. Its up to you.
Shown below: 69 series 3-1 gauge kit 69253-01. Musclecar inspired late 60s, early 70s mint green backlit graphics on a black background. Perfect for a resto-mod or pro-touring build.
Performance style: Bold modern graphics have a performance look without going overboard. Perimeter lit dials are easy to read day or night. A great choice for a more modern, performance inspired pro-touring look.
www.newvintageusa.com
Old 06-16-2013, 07:47 AM
TheShopLLC.com TheShopLLC.com is offline
Default Nvu, Powerblock,69 Camaro Dash Inserts
POWERBLOCK TV MUSCLECAR EPISODE 12, BUILT TO FIT NVU'S 69 SERIES GAUGES ARE A QUICK AND EASY UPGRADE FOR THE STOCK 69 CAMARO DASH.. ALL ITEMS IN STOCK
http://www.summitracing.com/parts/nvu-69253-01
http://www.summitracing.com/parts/nvu-88690-09
www.theshopllc.com
TheShopLLC.com
Old 06-16-2013, 08:19 AM
I would think those will be popular Mark.
