Old 04-06-2013, 11:00 AM
turboapex turboapex is offline
Default Help!!! who's headers will work?
I have a Chassisworks(Chris Alston)subframe for a 69 camaro and i'm looking for long tube headers that will fit a 6.2 or LS-9 engine in that subframe. Already tried DSE headers,frame would need to be modified(hits top inside corner of frame tube) on drivers side to fit.
Thanks Mike.
Old 04-06-2013, 09:19 PM
randy randy is offline
post a pic on where it would hit. Maybe someone else can compare it to their headers. What do you live? If you are in tx you can try mine
Old 04-07-2013, 12:20 AM
Hugger67RSSS's Avatar
Hugger67RSSS Hugger67RSSS is offline
Stainless Works Wayne Due headers will fit, just had them in a 69 with LS mock up block this week
Aarik
68 Camaro 6.0/T56, Jake's Rod Shop C6 Subframe, JRS Torque Arm, Ridetech TQ Coilovers
Old 04-08-2013, 05:54 PM
Thanks for the help guys,i will try to post some pics and i will check with stainless works.
Old 04-08-2013, 10:34 PM
not sure if this will help you. I love the way they fit
and engine is trans is mocked up on my buddies 69 dse subframe
its close so we are going to have to tilt the engine up some or mod the crossmember. chances are the crossmember will get flattened out.
the adapter will need to be turned the other way. currently its touching the headers
Overall the SW header clearance is amazing. they fit perfect in the subframe.
Old 04-09-2013, 10:31 AM
fesler's Avatar
fesler fesler is offline
Our SS Fesler LS headers will work on all LS engines for Chris Alston no issues.
http://www.shopfesler.com/fesler-sig...steel-headers/
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 04-10-2013, 12:11 PM
Chassisworks Chassisworks is offline
Supporting Vendor
Not all frames have the same clearances or put the engine in the same location. What works in a stock clip with an LS conversion will not necessarily work with our front clip. Or anyone else's for that matter.
Fesler builds a very nice quality header that will fit our clip no problem. Check it out and give them a call!
Old 04-15-2013, 05:44 PM
jeremy30thz's Avatar
jeremy30thz jeremy30thz is offline
Is this with the Wayne Due Stainless Works headers?
Old 07-10-2013, 03:36 AM
Dipped's Avatar
Dipped Dipped is offline
Even though they are $hitty headers that crack after 20k miles the s&p mid length do clear my chassisworks frame with an ls2. They also allow for a super clean 2.5" exhaust install. For $500 you get what you pay for. Cracks on cracks haha
1968 Firebird
lS3/T56/9"/24 Pistons/Forgeline VX1s/Faulty "Ride Height Too Low" Shocks
Old 07-19-2013, 11:17 AM
PrecisionRestor PrecisionRestor is offline
Default Street and Performance
Give Mark at Street and Performance in Arkansas a call. He's the man when it comes to the fit of parts on those first gen Camaros. 479-394-5711
www.PrecisionCarRestoration.com
