Old 10-27-2011, 11:31 PM
DENTGUY's Avatar
DENTGUY DENTGUY is offline
Default Inox Shoebox build
So, here goes. Absolutely love forum. Man are there a ton of amazing projects. I'm 4 years into a build that is starting to come together finally.
1956 Belair
Stainless tube chassis and cage
LS376 twin turbo
Tremec 6060
2010 Camaro IRS (refabbed out of stainless) and shortened 10"
Heavy duty axles
C6 front suspension
22x12 rear
20x8.5 front
The goal was to build a shoebox that hadn't been built a hundred times before. I always intended to do a Morrison Chassis until we dove into a bit more. So when I get a bit more comfortable with uploading pics and changing the dimensions, Ill post a few more.
Heres a few pics to get started.
Thanks fellas
Doug
03 SS Silverado 12.2 @ 108
07 TBSS- Work truck
56 Belair-Money Pit
Old 10-27-2011, 11:34 PM
daemon2's Avatar
daemon2 daemon2 is offline
Looks like a great start!
Daemon2
Old 10-27-2011, 11:44 PM
fleetus macmullitz's Avatar
Very cool to see a '56 turned into a beast.
Old 10-28-2011, 01:59 AM
Wow that is a killer project. Welcome.
Old 10-28-2011, 08:57 AM
xtreme's Avatar
xtreme xtreme is offline
any more pics of the suspension?
Old 10-28-2011, 09:04 AM
DENTGUY's Avatar
Actualy yes. A ton! I need to resize them a bit! Too small to see. I'll get on that this weekend. The rear is nearing completion. The front is actually done with mock LS motor and tremec mounted in frame.
Doug
07 TBSS- Work truck
56 Belair-Money Pit
Old 10-28-2011, 03:52 PM
ccm399 ccm399 is offline
Hey Doug,
Welcome!
So for the pics the best way to post them it to upload them to Photobucket or Flickr or some other Photo hosting site. Once hosted, you can copy the IMG link and paste it into your post on here. The pics will appear directly in the post and the other members will not have to click on a thumbnail to see the good stuff!
Hope that helps! Can't wait to see some more progress pics.
Chris
Checkout my '71 Pontiac Firebird Build Thread Click Here
Old 10-28-2011, 04:23 PM
DENTGUY's Avatar
A few more showing frame and stance. Mock motor.
Obviously, the frame in not complete, but here is a few in progress. Notice the cage and its inset into the body.
Doug
07 TBSS- Work truck
56 Belair-Money Pit
Old 11-19-2011, 04:01 PM
DENTGUY's Avatar
Well, car is coming along. We were able to narrow the 2010 Camaro rear end by 10 inches to our specs. Refab it out of tube and replace all those weak trailing arms with custom fully adjustable ones. Ordered up the HD axles to accompany the predicted power. All rubber bushings have been replaced with solid mounts to reduce any possiblity of flex.
The front clip is being re-attached to to body for fitment.
Doug
http://i1196.photobucket.com/albums/...5/cfbeeea8.jpg
And new refabbed armshttp://i1196.photobucket.com/albums/...5/85a5c61d.jpg
Completely refabbed 2010 Camaro rear endhttp://i1196.photobucket.com/albums/...5/cfdd07fe.jpg
All solid mounts and adjustable trailing armshttp://i1196.photobucket.com/albums/...5/50cd785a.jpg
Front clip being refitted to body.http://i1196.photobucket.com/albums/...5/5933d727.jpg
07 TBSS- Work truck
56 Belair-Money Pit
Old 11-25-2011, 11:46 PM
DENTGUY's Avatar
Heres a few more updates from today.
Rear subframe is inside car and we are fabbing mounts. A few pics of the trailing arms refabbed. A pretty good side view of stance of the car.
07 TBSS- Work truck
56 Belair-Money Pit
