Old 11-05-2013, 07:00 PM
st83 st83 is offline
Default 335/30/20 vs 345/25/20
Alright, so i just ordered my wheels and they should be here in about a month and I'm really torn about tire size! The wheel sizes are as follows:
20x12 rear
19x8 front
The car is a 69 Camaro, that has been minitubbed with DSE tubs and running a Speedtech torque arm rear and their road assault package in the front. The car is going to have a nice low stance. So as the title says, what do you guys think, 345/25/20's or 335/30/20's?! I'm worried that the 345's are a little to rubber bandish, and the 335's are a little to tall and I won't be able to get the right ride height! The front tire will be a 245/35/19 (Full front subframe for a wider tire wasn't in the budget unfortunately).
Obviously, pics go a long way ! I did a search but didn't find to many running the above combo's!
By the way, wheels are the brand new Hot Rods by Boyd 2 piece billet HR99's with Charcoal center and polished lip. I dealt with Chris Coddington and the customer service was nothing short of incredible, and the wheels should be here in 3 to 4 weeks. I will be sure to post up pictures when they arrive!
Old 11-05-2013, 09:22 PM
20x12 rear
19x8 front
245/35/19 = 25.75"OD (3.4" sidewall)
335/30/20 = 27.9"OD (4" sidewall)
345/25/20 = 26.8"OD (3.4" sidewall
As you can see above if you base it on your front tire size you have 3.4" sidewall and approx 25.75" overall height. With the 1" diameter larger rear tire you want to carry at a MINIMUM the same sidewall (relating to 1" taller rear tire).
The 345/25/20 matches the front tire perfectly!
However it depends on the look you want to go for. An approx 28" rear tire is pretty sall, so will give the car the "stuffed" look. It's over an inch taller than the other rear tire option and 2 inches taller than the front! Again depends on the look you're going for.
If it were me, I'd go the 345/25/20. You get the additional width (just less than 1/2" wider) which is always a good thing and it matches the front perfectly.
I'm going with 18/19 combo on mine, but for reference you can see us test fitting a 345/25/20 on my car so you can get an idea of the aspect ratio (sidewall).
Good luck!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 11-06-2013, 10:12 AM
jovozx12's Avatar
jovozx12 jovozx12 is offline
That's a 345 20 in the picture?
Old 11-06-2013, 11:19 PM
Yes. I have a full Rez picture that you can read the size on. We just test fit it for the width.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 11-08-2013, 06:44 PM
Well, after a lot of thought... I'm still not sold on one or the other! I'm pretty sure I'll be going with 345/25/20. Does anybody know if these will fit within the DSE mini tubs, or will more mods be required? Anybody have any experience running this tire size?
Old 11-08-2013, 09:49 PM
Mine pictured above is DSE tubs and notched frame.
Should fit no problem if you get offset in wheels right!
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 01-10-2014, 06:45 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Good luck!
I am having the same problem on what combo to use. I want the taller tire and I want the space on the right and left side of the tire filled up. I want the suffed look but I want it to look somewhat equal to the front in regards to tire size and look.
Do you have any photos of the car above setting on the ground? While on the ground did the wheels go up further inside?
Thanks.
Ron
1969 Firebird, 4-speed Coupe
Old 01-10-2014, 07:49 AM
Thanks.
I will try and get some more soon. My car will hopefully be out of the painter today and we're going to see about setting ride height and trying out some wheels with same tire. I will post as soon as I get more info. You guys are the first to receive the updates I post!
I want the stuffed look also so looking forward to ordering my own wheels/tires when I get it figured out fully. Hoping to get a hold of Anvil so I can get diff front inners and run 285 fronts
Texas A&M BSME 2008
1992 Corvette ZR-1
