Old 06-19-2013, 06:12 PM
mustangracer11 mustangracer11 is offline
Default my amx build
I started this build about 4 years ago. I took it to a shop to get the subframe and IRS installed it stayed there 2 years and only got the front sub-frame in. I finally went and got it and i'm putting the IRS in myself with the help of a friend and doing all the other work. I was hoping to be much further a long than I am but things just hasn't worked out that way. I have learned a lot from watching rons's amx build and reading on the forum. I wished I would have done a few things different but this is my first time building a car like this and cant wait till it's running I just wished I had more time to work on it.
Old 06-19-2013, 06:27 PM
The car looks to be in nice shape. Nice project!
Old 06-19-2013, 06:42 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
thats a cool project,I will watch this one for sure
Old 06-19-2013, 07:07 PM
Rick D's Avatar
Rick D Rick D is offline
Nice to see another AMX! Did they make the front clip or did you buy it from somewhere?
Rick
Old 06-19-2013, 07:36 PM
Thanks It did have some rust on the lower side of radiator support and where the battery was. That was the only major rust on the car.
Old 06-19-2013, 07:41 PM
It is a art morrison clip, I went with their narrow version because I was worried about the standard corvette width being to wide, I think it would have been fine though and wished I would have went with the wider track width that they offer. It's to late now though
Old 06-20-2013, 10:37 AM
Royalworks's Avatar
Royalworks Royalworks is offline
Just means you gotta find wider front tires. Not a bad problem to have.
Royalworks Speed Shop
Lincoln, NE
www.facebook.com/royalworksspeedshop
www.royalworksspeedshop.com
Old 05-26-2014, 07:43 AM
I've made some more progress in the past year. Having the car at my house has helped with having time to work on it. I decided to use GTO interior in it and I cut out the firewall and floor pan and will be using the GTO firewall and floor pan so everything will bolt back in. I should have done this before putting the subframe in but did not plan on the gto interior. I did find some rust in the rockers that was covered up with bondo.
Old 05-26-2014, 08:20 AM
Old 05-26-2014, 09:23 AM
coolwelder62's Avatar
Very nice.Cool project.
