Old 05-18-2014, 10:01 AM
RPitts's Avatar
RPitts RPitts is offline
Default Fuel line routing
Could anyone with the Morrison rear clip post some pictures? I am at a total stand still right now. I will post a picture of bottom of car to get some advice.
Old 05-18-2014, 11:06 AM
RPitts's Avatar
More Pics
Old 05-18-2014, 03:31 PM
It's hard to see but on this Art Morrison tri five chassis -- I ran it on top of the driver side frame rail (running an LS motor so hook up is on the driver side).
Old 05-18-2014, 03:37 PM
Old 05-18-2014, 03:47 PM
That's really helpful on a stub frame car.
Old 05-18-2014, 04:26 PM
True!
Old 05-18-2014, 07:09 PM
CURVES's Avatar
CURVES CURVES is offline
What about a sleeve (or sleeves) thru the rear crossmember? it looks like that would put the lines inside the frame rail behind the crossmember with clear path to the tank. It seems like that would be pretty clean, although it's a little hard to see in the photo because the lift pad is hiding the spot I'm talking about.
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 05-18-2014, 07:18 PM
Ron in SoCal's Avatar
Good thinking Scott. I know AME makes crossovers for brake lines but I've not checked the catalogue to see if they make them in fuel line sizes.
Ron in SoCal
69 Camaro in progress
Old 05-19-2014, 09:23 AM
RPitts's Avatar
Yea the pressure and return won’t work on top because of the sub frame is welded to the floor and the sub connectors are boxed as well. Good thought on the thru frame connectors that is what I am using for the break lines. Going to call Morrison to see if they have in 3/8". Thanks for the help!
Rob
Old 05-19-2014, 09:38 AM
They don't - nor does anyone else.
Fab up your own thru frame using STEEL fittings. Or put a "tubed sleeve" thru where you need to run your line -- allowing for the fitting to slip thru if needed for future service work.
