Squishy
I've had an ever increasing difficulty dialing in my brakes.
Seems no matter what I do the top half of the pedal is squishy.
I've bleed and bleed the brakes, not sure if I should pull the master and re bleed it.
It's a Belair with a Dutchman/willwood 4 piston front conversion.
I may also not be creating enough vacuum, as the cam makes the idle pretty lumpy.
Considering pulling the vacuum booster and going to manual, can't decide if I'll need a new master.
And or the advantages over manual vrs power.
I eventually will do some auto crossing with it and heavy river road use.
Just trying decide my next move, any suggestions are greatly appreciated.
