					Originally Posted by Neil B  I use a degree wheel and a dial indicator on the valve tip with a checking spring installed.  I check in 5 degree increments from 10 degrees BTDC to 10 degrees ATDC. |
 x2.  I have a used head gasket for the procedure.  I find this method lots easier and more accurate than the clay method.
