Old 03-31-2017, 06:16 AM
paulk68 paulk68 is offline
Default LS engine stand
Does anyone have one of these taking up space that they would like to sell? i figured this would be a good way to set up my bellhousing. Let me know
http://sdparts.com/i-23850689-sdpc-g...h-casters.html
Old 03-31-2017, 01:44 PM
For that matter does anyone with some knowledge and ability. Know necessary measurements and angles for those of us who would like to build their own?
Old 03-31-2017, 06:52 PM
Che70velle's Avatar
I have a couple sets of these, for sbc. My engine builder gave me a set, with my race engines. He had them built, and they were much lower to the ground, than these are. We ran shallow dry sump pans, so the height was perfect for transport, and storage.
Ryan, I am going to build my own for my LS , out of tubing, instead of square stock. Center the engine over the cradle, (feet) and you'll be fine. Angles don't matter, and cross bracing isn't needed. My race engines were cast iron block and head, and didn't have cross bracing. They held up beautifully. Get your height right for your oil pan, and your golden. Make sure the feet are about as wide as the outside of the valve covers. I never had wheels on mine...that would be nice to have.
Thanks Dad!!
Old 03-31-2017, 09:01 PM
Problem is Scott the engine is at the builders at the very bottom of the pile lol so to say ...and I haven't got a pan yet as its a ls7 and I'm converting to ls3 wet sump , not sure what pan to use ... I want to push the engine back as far as possible with major hacking of the firewall
Old 04-12-2017, 11:09 AM
jwcarguy jwcarguy is offline
Banned
These are simple enough to build
Just make them tall enough to clear any oil pan, then they can be used on any future engine
You could always start with engine mounting plates (like we use in off road sand rail builds), then build off them
example: https://www.tabzone.com/12106-01B-LS...LATE_p_71.html
I prefer the casters than screw in from bottom, so easily removed, to be more secure during transport, say in back of truck, etc
Old 04-13-2017, 07:02 AM
samckitt's Avatar
samckitt samckitt is offline
Like mentioned above. Build one.
Scot
86 Monte SS
LS2/T56 Magnum
