Old 12-01-2020, 09:56 AM
gnx7's Avatar
gnx7 gnx7 is offline
Default new Tremec TKX 5speed is out! 8000rpm shifts rated at 600 ft/lbs
For those of you unhappy with your TKO600 here is the newest offering from Tremec..... the TKX 5speed!
https://www.hotrod.com/articles/trem...ssion-install/
Higher RPM shifting and smoother shifting
I'm sure the torque rating is very conservative.... as the T56 Magnum is rated at 700 ft/lbs .... and plenty of us are pushing 1000rwtq thru them without issues.
The Following 2 Users Say Thank You to gnx7 For This Useful Post:
camcojb (12-01-2020), jarhead (03-29-2021)
Old 03-20-2021, 11:14 AM
gnx7's Avatar
Has anyone driven the TKX yet? How does it compare to a T56 Magnum (Fstyle)?
Old 03-22-2021, 11:30 AM
cabudge09 cabudge09 is offline
I've got my TKX in the car since summer last year but the build isn't done so I haven't driven it yet. No mod to the trans tunnel was required. I am coming from a T-5Z with a small block ford making 350hp. The car now has an LS7 making over 500whp. Should be fun
The Following 3 Users Say Thank You to cabudge09 For This Useful Post:
andrewb70 (07-19-2021), camcojb (03-22-2021), jarhead (03-29-2021)
Old 07-13-2021, 04:08 PM
68454RS's Avatar
68454RS 68454RS is offline
ANy updates on the performance of the TKX ?
Old 07-13-2021, 04:49 PM
dontlifttoshift's Avatar
I have installed two.
One replaced a TKO and the customer was ecstatic. Shifts are so much cleaner.
The other replaced a Richmond 5 speed and that was also significantly nicer to drive.
Shift throws seemed long to me but both cars had relatively tall shifters and I am comparing to the 6" stick on my T56. I didn't get to really wail on either car so I can not comment on high rpm shifting.
Donny
The Following 5 Users Say Thank You to dontlifttoshift For This Useful Post:
68454RS (07-13-2021), andrewb70 (07-19-2021), dhutton (07-14-2021), GNon18s (07-19-2021), RdHuggr68 (07-17-2021)
Old 07-20-2021, 09:54 AM
gnx7's Avatar
I just sold a customer a close ratio TKX with the .81 5th gear. Hopefully he will be driving it this month and give us some feedback. LS swapped 70's C10 truck
The Following User Says Thank You to gnx7 For This Useful Post:
68454RS (07-21-2021)
