Old 02-06-2023, 08:41 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Default MIssfire under Boost
Hello and hope you can help. I have a 383 SBC with Fast XFI 1.0, Holley Stealth Ram, and P-1SC Procharger. I have a MSD 6AL box and MSD Coil. I dont know alot, and have been chasing a problem. It just started within the last year. It runs great from idle to when boost starts. Once the boost kicks in (about at 4-5 PSI), the motor starts to misfire and cut out. I have replaced the cap and rotor, plug wire and gone thru several sets of plugs. Any ideas I can check? Thanks for your help.
Mike
Mike
Old 02-06-2023, 10:48 AM
camcojb camcojb is online now
What happens to the A/F and fuel pressure when this occurs? Does your fuel regulator have a boost reference line? Do you have the proper MAP sensor? Plug gap?
Old 02-06-2023, 02:32 PM
mdprovee's Avatar
To be honest I do not know what happens to either of those, as I don't have a guage for them. Something I will be working on. This system has been working for the last 10-12 yeas and recently started to give me heartburn. The spark plugs are gapped to .030".
Mike
Old 02-06-2023, 04:05 PM
You should be able to see if it's going lean or rich by datalogging it. I would start with that.
Old 02-07-2023, 05:20 PM
ADY's Avatar
ADY ADY is online now
A friend used RPM (https://www.rpmeng.com/dyno-tuning-rohnert-park) in Rohnert Park a couple years back for TBI/EFI tuning help. Had good feedback and not too far of a drive from Suisun City.
-Adam
1968 Camaro SS
Old 02-08-2023, 08:40 AM
mdprovee's Avatar
Thanks, going to try and see if I can get some datalogging done this weekend, and will check on RPM.
Mike
Old 02-19-2023, 04:41 PM
mdprovee's Avatar
I took the car out today and removed the blower intake tube so the motor saw no boost. No cut out till the motor hit the rev limiter at 5500RPM. Then we connected the intake tube back up and ran it. The RPMs are around 4500 to 5000 RPM when it cuts out and around 7 lbs boost according to the guages. Here are the data logs. My plugs at set at .025 gap. Please keep in mind it is a manual car, so the big dips are me shifting.
Mike
Old 02-19-2023, 10:25 PM
Musclerodz's Avatar
personally I would throw the MSD box in the trash. Every car I have ever used one on would eventually have issues. I would tighten your plug gap another .005.
Mike Redpath
Musclerodz & Customz
facebook page
The Following 3 Users Say Thank You to Musclerodz For This Useful Post:
camcojb (02-20-2023), fleetus macmullitz (06-10-2023), Tinker (02-20-2023)
Old 06-09-2023, 09:07 PM
mdprovee's Avatar
Its been a while and life got in the way of fixing the car. Took it to RPM and they were amazing. Made a appointment and they got the car right in. It was a rusty distributor. After replacing the distributor, they did a little tuning and it is running great. 475 horsepower to the wheels.
Thanks for the referral.
Mike
The Following 2 Users Say Thank You to mdprovee For This Useful Post:
camcojb (06-09-2023), fleetus macmullitz (06-10-2023)
Old 06-10-2023, 05:47 PM
thedugan's Avatar
thedugan thedugan is offline
Wow. What would cause all of that rust?
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
