Old 11-26-2023, 04:05 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default FS: LSA built longblock, LS9 Katech heads, LS7 Gromm heads
Item Location (City/State): San Ramon, CA
Price: $2600
Description:
Looking at building a 1500hp+ L8T engine so need to sell some LS parts I've accumulated!
Fresh 4.070" LSA block with Molnar 3.622" forged crank (58x and 6 bolt rear flexplate style), Molnar PWR ADR rods with ARP2000 bolts, CP race pistons with .230" wall wrist pins, machined, balanced, file fit rings for boost assembled by Joe's Engine shop in Concord, CA (used to run NHRA... they have built a ton of LS engines for myself and buddies). Includes ARP2000 head studs that were used for the torque plate/honing/boring.
$8K
1 set of freshly done LSA heads CnC ported by Gromm Racing, LS3 intake valves, LY6 Inconnel exhaust valves, new guides, BTR .660" lift spring kit $2600
1 set of freshly done LS9 heads CnC ported then hand finished by Katech Racing, LS9 Ti intake valves with s/s exhaust valves (per their spec), new guides, BTR .660" lift spring kit $3000
1 set of freshly done LS7 heads CNC ported by Gromm Racing LS7 Ti intake valves, with s/s exhaust valves (per their spec), new guides, BTR .660" lift spring kit $2600
I have factory LS3/LS7 rocker arms as well as LS3 aftermarket BTR rocker arms (shaft setup) if needed.
