Old 03-16-2005, 05:23 PM
JamesJ JamesJ is offline
Default DSE Trans Crossmember
Not sure if anyone on this site has one of DSE earlier cars where they made the transmission crossmember out of 2X3 square tubing. I was wondering if anyone thought of how beneficial this was, how much more exhaust clearance was attained, and then with the extra exhaust clearance you could say that it gave you better ground clearance. Just wanted to here what some ideas were on this method. Do you think that the modification to the trans tunnel is very noticeable, and would that be to much of a change to run the stock console in the factory location. Some pictures can be found here http://www.detroitspeed.com/ScottsPage10.html
Old 03-16-2005, 05:27 PM
spaztikatik spaztikatik is offline
I got mine from G-force crossmembers, http://www.transmissioncenter.net/gf...ssmembers_.htm
check it out, it's beastly and should work great, I dunno what the offer as far as first gen camaros are concerned, but i'm sure they offer somehting for you
Old 03-23-2005, 06:18 PM
Ok maybe I will start, obviously it adds some amount of structural integrity, but how much? With all the talk about cages not being safe if you don’t use the correct amount of precautions, is this a good alternative assuming that you have sub-frame connector and have some type of shock crossmember that also adds to the structural integrity? Or what would it take to get similar results of a caged car?
Old 03-23-2005, 07:23 PM
Nutsy Nutsy is offline
These may seem like really nOOb questions,however, I am a bit confused. I have been away from my car for 2 years and can't remember what the underneath looks like.
Why does the DSE crossmember require hacking up the floor and welding it all in?
AFAIK ATS, Keisler and other crossmembers are bolt on, but where do they bolt to? Is their any advantage to welding the crossmember? Is DSE's style of crossmember better than the others?
Does anyone have pictures to show the different type of crossmembers installed with a T-56?
I need some clairification.
Trev
Old 03-23-2005, 08:55 PM
907rs's Avatar
907rs 907rs is offline
Trev, the DSE crossmember is tucked up into floor similar to their subframe connectors, and runs from one rocker panel to the other in length. The only portion of it that hangs below the subframe is the actual transmission mount. They built it in this fashion to allow for better exhaust clearance as well as to stiffen the chassis itself.
The other crossmembers you see advertised span from one rail of the subframe to the other.
You can see DSE's here.
Bill
Old 03-23-2005, 09:30 PM
Ok, so why did they have to cut the tunnel up so much? Is it because they used lowered body mounts or does the DSE crossmember make the tranny sit higher in the tunnel? Do the other cross member kits require you to cut up the tunnel that much too?
The DSE crosmember just looks a lot more heavy duty then the others i have seen. Im just wondering why everyone else hasn't done it this way.
Old 03-23-2005, 10:47 PM
907rs's Avatar
Trev, how about we start a new thread on this subject? I'd be happy to help answer any questions.
Didn't mean to hi-jack yours, James.
Bill
Old 03-24-2005, 12:53 AM
heck if you are talking about the crossmember I dont care.
Old 03-24-2005, 06:12 AM
69Lt4's Avatar
69Lt4 69Lt4 is offline
I installed the DSE cross member to two reasons. One it doesn't hang down except where it attachs to the trans. This allows me to run the exhaust as close to the floor as possible. Second, easy of removing the transmission. 8 small bolts and a small piece of metal. Nothing expanding accross the width of the car. In the DSE pictures, you see part of the trans tunnel cut. The trans tunnel is raised about 3/4" to 1". In most camaros when the engine and trans angles are set correctly they will be very close to the floor. Most poeple raise the floor to ensure the trans doesn't contact the floor during vehicle use.
Kevin
Old 03-24-2005, 09:56 AM
When you installed the DSE crossmember, is there any template or instructions that they provide to cut up the floor with? Also do all T56 trannys the same mounting point? The reason i ask is i want to do all the metal work on the car without the transmission and engine if possible.
