Old 12-14-2006, 12:48 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default Time Involved To Tub A Car?
I'm picking up my car on saturday...(Its ready but i'm not)
I had custom tubs installed and am a BIT skeptical on my bill. I had some done before (same shop) and it costed me MUCH less than they are charging me now...I know there are a few more brakets and stuff to attend with the vert but still. Can anyone chip in and share their experience with tub install timeframe?
I'll give you the time i'm being charged after a few inputs to compare. I don't wanna influence the audience!
Thanks guy's....I need a boost today.
Lead.
I had the DSE connectors installed too and the alum sub-frame bushings. Frame was almost perfect with only one mount to repare. Car was stripped down when they got it too. If you feel like cueing in those times too...Be my guest!
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 12-14-2006, 02:00 PM
68protouring454's Avatar
really depends what they did, did they add bracing for the convert?? or did they simply mini tub it??
usually all said and done a mini tub will take 40-50 hrs on a coupe car or rag top with no additional bracing added, however in a rag top you must add bracing if yu want your doors to close after hammering on it driving
Old 12-14-2006, 02:40 PM
TLWiltman TLWiltman is offline
I've heard a figures from 25-40hrs (depends on the person/shop) for a minitub (2nd gen Camaro). 2nd gens are (IIRC) considered to be a fairly easy car to minitub. Not sure how much more time a 1st gen would take or how much extra time/engineering would be required for a convertible.
Old 12-14-2006, 02:59 PM
also i believe dse estimates 50 hrs for them to do the job
and they have done many
Old 12-14-2006, 05:07 PM
Leadfoot1's Avatar
OK.....
Thanks then.
I had read the DSE hours somewhere and couldn't fint it. I was hoping someone would remember.
The shop is saying it took them 60 hours for the whole thing. (Car's been there 3 weeks as the worked on it on and off and i am so busy i went only twice, so i couldn't follow them).
Its just that it costed me like 500$ on my coupe for the tubs alone...And now its costing 60 hours at 60$....Do the math.
'Guess i'll have a bit of time to clean my undercarriage before i'm buying the suspension.
Oh well, at least i can fit the tires now!
Thanks guy's.
Lead.
Oh, and where would bracing be needed? We doubled the rails with 1/4" plate at the notch and the DSE connectors stiifen up the car considerably. Just opening and closing the doors is amazing (before and after)! I'm planning a cage like this Stavola guy on DSE's website (almost hidden) but maybe not right now, unless i realize bending tubes is as easy as it looks. My friend just bought a bender and we are suppose to play with it during the holidays.
LEADFOOT1
Old 12-16-2006, 09:55 PM
Default Mini Tub install cost
Hi I'm having a set of DSE tubs put in my car they are charging me $700 for the work
Old 12-21-2006, 10:34 PM
Datsbad's Avatar
Datsbad Datsbad is offline
WOW , thats way to cheap . I am curious as to what this looks like in the end!
Also , I have done 2 verts and one we are doing now. There is nothing to worry about doing a vert . The car we are doing now has good paint and we are mini tubbing it and its on a rotiserre. I of course added bracing to it that will be removed after we are done.
I see that it will be more structualy sound than stock . With plating that is thicker than the factory rails and a crossmember to boot how could it not be, The convert back brace does not need to come out if your not doing a stagered crossmember. !
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 12-21-2006, 11:27 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Do you think the hours needed to do the job would be that much if the floors and stuff were already cut out? Does this make the job easier and less time consuming since a lot of stuff is out of the way?
Old 12-21-2006, 11:30 PM
Datsbad's Avatar
it would make it easier to some degree, floors or not the frame still has to be sectioned , which is the hardest part.
cutting out tubs and fitting them is no big deal but you need a outer wheel house in there to mate it up properly
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 12-22-2006, 12:14 AM
I thin 60 hours was on the money
Frank Serafine
