Old 09-24-2007, 07:26 AM
Radlark's Avatar
Radlark Radlark is offline
Default Air Ride setup /Hot Rod Air AC setup 4 Chevelle $1800 FIRM WILL NOT SEPERATE!!
I have a Hot Rod Air AC setup designed for the chevelles, it has the polished compressor, billet vents, controls, everything is brand I only used the box as a mock up for the mounting brackets, comes with all hoses as well, I also have an air ride setup by Slam Specialties it has the polished Viar air compressors, 2-5 gallon tanks, air lines, switches, valves, YOU NEED TO SUPPLY THE BRACKETS FOR THE BAGS AND SHOCKS FOR YOUR APPLICATION (air ride technologies) also brand new still in the box.
I am selling these as a package unit ONLY please do not ask me to seperate the price includes shipping, ONCE AGAIN I AM SELLING THIS AS A PACKAGE! they will ship out of Southern California. I can get pics if need be but as I said everything is brand new in the box!
Old 09-24-2007, 02:03 PM
4mm 4mm is offline
Is the AC setup for cars with oem AC or without?
Old 09-24-2007, 02:14 PM
Radlark's Avatar
It's for cars without air here is more info on what I have
The AC kit will fit any A-body from 64-72, you can change the control panel if you like.
http://www.hotrodair.com/index.cfm/p...prod/prd33.htm
http://www.hotrodair.com/index.cfm/p...rod/prd122.htm
http://www.hotrodair.com/index.cfm/p...rod/prd109.htm
http://www.hotrodair.com/index.cfm/p...prod/prd55.htm
http://www.hotrodair.com/index.cfm/p...prod/prd59.htm
http://www.hotrodair.com/index.cfm/p...prod/prd79.htm
