Old 01-29-2008, 08:50 PM
blown71nova blown71nova is offline
Default Set of 8 JE Dome Forged Aluminum 400 SBC Pistons
Comes with Pistons and Wrist Pins Only!!
You Will Need To Get New Spiral Locks & Rings For These Pistons!!
UNINSTALLED FROM A BRAND NEW DART 400 SHORT BLOCK...NEVER RAN!!!!!!
PLEASE READ: Pistons were installed in a unfinished new dart 400 short block and the engine never got finished being put together...I changed the direction i was going with the 400 dart block and took the pistons out and I no longer need them for the application i am using
Summit Racing Part Number# JEP-182053-8
400 Small Block Chevy
JE Pistons offer excellent quality at an affordable price.
With more than 50 years of experience, it's no wonder JE is the world's leader in high performance pistons. How do they stay in front? Easy--they do it by constantly improving designs, materials, and production processes, using state-of-the-art machining techniques, and incorporating other methods to keep costs low. The result is a line of great, economically priced JE Pistons with features such as radiused valve reliefs (where applicable), forced piston-pin oilers, diamond-turned skirts, gas ports, and much, much more!
Bore (in): 4.125 in.
Bore (mm): 104.775mm
Piston Style: Dome, with two valve reliefs
Piston Material: Forged aluminum
Compression Distance (in): 1.125 in.
Dome Height (in): 0.125 in.
Piston Head Volume (cc): -3.00cc
Wrist Pin Style: Press fit or floating
Pin Diameter (in): 0.927 in.
Piston Ring Thickness: 1/16 in. x 1/16 in. x 3/16 in.
Quantity: Sold as a set of 8.
Notes: Will fit most aftermarket 23 degree heads. Solid dome design. Gram weight: 450g.
Will Not Fit: Pro Topline or Brodix 11X cylinder heads.
Do Some More Research to Check and See If These Pistons Will Fit Your Application
Costs Me New From Summit Racing $786
My Loss is Your Gain!!!!!
$350 Plus Shipping!!!!!
Old 02-05-2008, 03:01 PM
bump!!!!!
Old 02-06-2008, 08:56 PM
sold!!!!
