Old 12-19-2007, 12:15 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default 427 LSx or LS7?
Hello:
I just read an article on, "How to build a 427 LSx".
Not a bad read, however it only makes 550 hp. Not bad, but an LS7 can easily make that with a little bit if effort.
When it came down to discuss the price of he LSx, it said about $12,000!
Who would build one of these when you can have a Aluminum Block 427 for the same price as an iron block 427?
Did this cross anyone else's mind?
Ty
Old 12-19-2007, 04:24 AM
Lateral-g Moderator
Cam, headers puts the LS7 at around 600 hp if I recall. Scott, Jody?
Old 12-19-2007, 05:35 AM
JUSTANOVA JUSTANOVA is offline
Dont forget the added costs of the dry sump parts that aren't included in the crate engine price on the ls7
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 12-19-2007, 06:01 AM
James OLC's Avatar
In my opinion (and depending on your application), naturally aspirated the LS7 is a better choice while the LSx would have an advantage if you were going forced induction. The LS7 has some other advantages, especially with respect to rotating mass which is nice as well. Equipping the dry sump in not that great an expense - Tyler at ATS has all the pieces available for that and the cost is really quiet reasonable; packaging is slightly more complex - you wind up with a lot going on under the hood.
I am biased here though, our LS7 is at Katech right now.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 12-19-2007, 07:04 AM
TravisB TravisB is offline
not sure who built the 427 LSx but 550 is mild for one of those. Considering for bascially no extra money you can build more cubes with an LSx up to almost 500ci I believe. There are several companies out there building 427-440ci LSx engines that make well into the 600hp range up to 700hp in some cases depending on cam and heads. Durability of the LSx block has to be better than the aluminum block.
Kenny Davis Hot Rods
Old 12-19-2007, 07:52 PM
tyoneal's Avatar
I think it was the new PHR, or Super Chevy. You'll see it advertised at the very top.
Ty
Old 12-19-2007, 09:54 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
The only dry sump parts needed on an LS7 is the oil tank, hose adaptor for pan, and hoses, oil pump is internal and included.
Add an aftermarket dry sump to a LS2, see what that costs!
The article was SC, and it was an LSx built with a stock LS7 cam and components. Basically an iron LS7. It'd be good for a bunch of NOS.
Only reason to do it. IMO.
We have dyno tested 650 and 700 na packages available for LS7, includes upgrade rod bolts, chamfering the rod caps for the bigger radius on the bolts. headwork, cam, MAF, intake. Also 1000+ LS7 twin turbo. We've done over 30 LS7's this year. (Haven't done a single LS1 or LS2 this year.) No need for the iron block up to 1200 hp or so in my experience. THe LS7 has a longer cylinder wall, that is better for strokers, we did one with a +.25 stroke. The tall deck LSx is best for a stroker, but I'm not sure if that one is really available yet either.
We've had an LSX iron block for months for a magazine article, waiting for GM to release the heads with extra bolts, not available yet. And the bolt pattern is different than the World Products LSX.
Thanks,
Jeff Schwartz
SchwartzPerformance
Website : Facebook : Twitter
Old 12-19-2007, 10:31 PM
rocketman's Avatar
Stock Z06's are in the 530-540hp range bone stock.There are a bunch of dyno pulls to back this on the net. I would do a 454 LSX and spray it.
Old 12-20-2007, 01:20 AM
victionone victionone is offline
I had to make the same decision and went with a LS7. The GM crate LS7 was a few thousand dollars cheaper btw. The LSX has a few extra cubes and is bulletproof. I don't plan to make 1000+ hp and the 454 LSX's aren't making any more power than a 427 LS7. The LS7 has a lighter rotating assembly, aluminum block, dry sump, and was cheaper.
Vic N
Old 12-20-2007, 07:12 AM
that depends on who builds the 454 LSx....
