Old 01-22-2008, 10:56 AM
av8or32 av8or32 is offline
Default 69 Firebird Hotchkis question
I have a 69 Firebird and just recently finished installing the Hotchkis TVS. The front end seems higher than the rear. Is this normal? By the way, they recommended BB springs for the 400 Pontiac engine. Has anyone seen this and what sort of mod will I need to get the front end down?
Old 01-22-2008, 04:56 PM
Well, I disagree with the big block springs. Any Pontiac motor is much closer to the weight of a small block Chevy then a big block. With that said, the Hotchkis springs do settle a bit. But you probably have to strong springs.
Frank Serafine
Old 01-22-2008, 06:04 PM
what do you think I should do to get the front end down where it should be?
Old 01-22-2008, 06:35 PM
brownz brownz is offline
I know that alote of people cut the spring have not seen anymore than one loop so wouldnt do more than that but as far as the bb spring not sure. even hothkis cut the spring in the sec gen project to get it to sit right. they are setup for stock cars steel everthing.
Old 01-22-2008, 07:42 PM
maybe I should swap the bb springs for the sb ones
Old 01-22-2008, 07:56 PM
Big Injun Dave's Avatar
Big Injun Dave Big Injun Dave is offline
When I began the build of Project Greenbird we were the first first gen Firebird. We started with the BB springs and then ended up with the SB. They are the same wire size just a half coil shorter. You can adjust your own ride hight if you want.
You can see the rest of our project over on www.geetotiger.com.
PS: All cast iron 455 with A/C.
Dave "Big Injun" Anderson
[email protected]
