Old 02-24-2008, 03:16 PM
69bird 69bird is offline
Default Primer Question
My car is in DP90 right now sprayed about 6 months ago. I was told I could not spray a filler primer over it without spraying a fresh coat of dp over it first? Is this true?
Old 02-24-2008, 04:04 PM
68protouring454's Avatar
no, just sand the dp 90, if using polyester primer block dp 90 with 80 grit, if using urethane primer use 150-180 grit. use hard blocks and this will allow you to find imperfections and body work them alittle more before priming.
Jake's Rod Shop
