Old 05-01-2008, 11:57 AM
John510's Avatar
John510 John510 is offline
Default Fitting my 00 SS brakes to a 1st gen camaro
OK so Ive made posts on other site and had people respond but nobody has actually helped me on what Im trying to do. How do I get my 2000 camaro SS brakes to fit on my 68 camaro? Someone said get drum spindles but will they bolt right up to them or do I need some adaptors?
Anyone know a specific adaptor I can buy or how I can install them to my car? Thanks
Old 05-01-2008, 02:41 PM
LCAC_Man LCAC_Man is offline
http://www.camaros.net/forums/showth...615#post988615
Len
67 Camaro SS350 Convertible
406/200r4
Len's PT Garage
Old 05-01-2008, 04:28 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
I did this swap on my 72 nova a couple of years ago. I removed my drum brake hubs (also need drum brake front spindles), took them to a local machine shop and had the outside diameter turned down to fit inside the Camaro rotor. You also have to grind down about 3/16" off the top of the drum spindles. As for caliper brackets I made my own using a template i found on some site (sorry cant remember where) I also used the booster and master cylinder from a 4th gen camaro so everything worked. For the rear i just got 2 left side caliper brackets and they worked great with the staggard shocks. PM me if you have any questions.
Heres some pics;
Old 05-01-2008, 04:29 PM
70TWO NOVA's Avatar
Old 05-16-2008, 08:50 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default ls1 brackets
I carry LS1 brake brackets, e-mail is best [email protected] PM sent
as im not on here too often
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
