Old 06-22-2008, 12:23 PM
Les69 Les69 is offline
Default Widest rim on 69 Camaro
I couldn't find this in a search anywhere but I was curious to know what's the widest size rim you can fit on a 69 camaro without tubing it? I want to put some 20x11s on mine but I'm not sure if I want to go through with the mini tube...
Old 06-22-2008, 12:44 PM
camcojb camcojb is online now
pretty much too wide for the stock wheelwells. 9.5-10" max with a 275/40 or similar is about unless you are willing to lift the car up in the rear so it can't rub, and that doesn't look real good in my opinion.
Old 06-22-2008, 01:25 PM
Echo!
Frank Serafine
Old 06-22-2008, 01:36 PM
fesler's Avatar
fesler fesler is offline
times 4
Tub it the only way to do it right for the look you want.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 06-23-2008, 09:26 AM
I guess I have to tub it then! thanks for the info!
