Old 12-14-2008, 08:09 PM
vicious69's Avatar
vicious69 vicious69 is offline
Default LS1 rear disc setup
Hey guys I need some help on my LS1 rear disc brake setup for my 69 camaro. Does it matter if the calipers are mounted to the rear? I know if I go by what it says on the brackets then they are mounted to the front side of the rotors. I want to mount these to the rear so I can run the ebrake cable to the original location but want to make sure they will give me the most stopping power and be safe. Thanks
1969 camaro pace car Z11
1969 Camaro X44 Pro Touring 383 6spd
1967 Chevelle Resto Mod LS2
Old 12-14-2008, 10:52 PM
deuce_454's Avatar
as long as you can bleed the air it doesnt matter
Jake: Hit it.
Old 12-15-2008, 04:33 AM
dhutton dhutton is offline
I mounted mine that way. Just swap sides.
