Old 01-11-2009, 01:35 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Broken fender bolt won't come out!!
So I need your guy's advice on how to get a broken fender bolt out. I tried welding a nut on the end...no luck. Kept breaking off. The weld didn't want to stick all that great. I've drilled the center out and used two different type of easy outs...no luck. I've soaked it with liquid wrench...you guessed it...no luck. Today I used an oxy torch and heated the area up around the bolt and tried the easy out's again...no luck. Any one have any suggestions. Here's a pic:
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
