Old 09-23-2017, 02:02 PM
DT69Cam DT69Cam is offline
Default LS3 starter choice
Which starter did you guys use for your LS3 with a Manual trans ?? The GMPP instruction sheet states use the 10465385 starter. I have been coming across another starter, #299. How about the starter bolts ? Thanks!
69 Camaro Convertible (LS3/TKO in the works)
Old 09-23-2017, 03:45 PM
dontlifttoshift's Avatar
That part number is stupid money, it might be an awesome starter....:shrug:
Try this.
ACDelco Starters 12617229
ACDelco 11610787 bolts
ACDelco PT170 GM Original Equipment 1-Way Female Black Multi-Purpose Pigtail to plug into the starter.
All in for less than 150.
Or a Powermaster 9201 comes with bolts and has a bolt on connection for the 'S' wire.
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
kwhizz (05-18-2021)
Old 09-23-2017, 07:37 PM
Thank you Donny.
Donny
Old 09-25-2017, 04:16 PM
andrewb70's Avatar
Try this.
I like that starter too. That's the gen 5 Camaro unit. There is also a nice OEM heat shield that mounts to it. I used it on my Cougar.
Andrew
The Following User Says Thank You to andrewb70 For This Useful Post:
camcojb (05-12-2021)
Old 09-25-2017, 04:39 PM
Andrew
Thank you Andrew, I ordered the parts.
Old 09-30-2017, 01:29 PM
Well guys I picked up the #229 starter. Man its real close to my Holley/Hooker 2262 headers. Forget the heat shield..
Old 05-12-2021, 10:39 AM
paulk68 paulk68 is offline
Wondering if you guys needed to shim this starter at all? I am getting ready to install mine this weekend. thanks
