Old 02-24-2009, 09:54 AM
Rusty G Rusty G is offline
Default Double rear sway bar experiment (pic for Marcus)
I was under the wagon fixing more stuff from my pothole adventure and got to thinking.
Why not see if the car will like more rear bar.
I already have a 1" aftermarket bar which mounts on it's own brackets. I also welded them in when I boxed the arms.
Figured I could add a second bar to the stock mounting point and see if the car liked it. Took some twising to get it in but I added another 7/8" bar.
I love it, made a huge difference in the car.
Now the search is on for a larger single bar to replace the 2, something in the 1 1/4" area should be right if my math is correct.
Marcus, you seemed intriqued on the phone and since you were having email trouble I thought I would post it for you to see.
Old 02-25-2009, 07:40 AM
Marcus SC&C's Avatar
I have to admit it`s the first time I`ve seen that done... Mark SC&C
Old 02-25-2009, 09:48 AM
ironworks's Avatar
So what does it sound like with 2 different mufflers?
Rodger
Old 02-25-2009, 10:09 AM
Silver69Camaro Silver69Camaro is offline
Did you corner hard enough with that to see if it oversteers? Two bars would be a huge increase in roll stiffness, and I would expect it to almost give most vehicles a snap oversteer condition. A 1-1/4" bar is absolutely massive and I'd never attempt it, unless if it's a F350 with a towing package.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 02-25-2009, 05:15 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
I would take it one further ....weld the housing to the frame
www.pro-touringf-body.com
Old 02-28-2009, 07:13 AM
Ironworks,sound is not bad. I hate Slowmasters, it is on the "to do" list to be replaced.
Silver69Camaro, the car is a true daily driver and I never speed . I can take turns at double thier posted speed though.
I don't feel 1 1/4 is that massive. The 2 bars now are only slightly "stiffer" then what a single 1 1/4 would be.
One thing to remember is a Gbody bar is bolted to the lower control arm, it acts like a big lever, think breaker bar.
I did some quick and dirty math comparing a 1 1/4" bar mount "Fbody style" vs. "Gbody style".
Since the lever is roughly twice as long it reduces it's "effectiveness" by 45% compared to Fbody mounted bar.
So the 1 1/4" bar on my car is equivalent to a 11/16" bar on 3rd gene Fbody.
I am a drag racer, so take this all with a grain of salt since this is my first attempt to make a car turn.
The front bar is a 36mm Fbody bar, does it seem like a better match now?
Feel free to tell me if my thoughts on this are wrong.
I am always willing to learn.
Oh,pro-tour79, nice!
Old 02-28-2009, 08:11 AM
deuce_454's Avatar
and run solid rear tires
Jake: Hit it.
