Old 03-20-2009, 07:52 PM
g356gear's Avatar
g356gear g356gear is offline
Default Recommended timing for 454??
Hey guys,
I have a fairly fresh 454 with an agressive hydraulic cam and I am looking for recommendations for timing setting on the motor. Compression is around 9.5 and will be running 91 octane. The car was restored in 89 and had about 250 break-in miles before it was stored and never really had a good performance tune. I now have the car so I need a good starting point. Thanks for the help.
Old 03-20-2009, 08:37 PM
What distributor? Different distributors have different amounts of advance in them. Some are tunable, like MSD for example and other aftermarket distributors. You want 34 to 36 and want to be all in at 3000 RPM. I would reverse time it, set it at 36 at 3000RPM. While watching the mark, blip it from 3000RPMs to 4000RPM or so to make sure the timing is all in, and then let it idle and see where you are.
Most distributors will have about 20 degrees advance in the, so your base timing will probably end up somewhere in the 14 to 16 range?
Frank Serafine
Old 03-20-2009, 09:01 PM
I agree with Frank, the distributor is important. However you can total time it to 34-36 and let the cards fall where they will. If you have a large cam you want as much initial as you can get. That can be achieved with a vaccum advance or changing out bushings in the distributor.
Old 03-21-2009, 09:17 AM
g356gear's Avatar
Sorry, forgot to mention. This is an original distributor from 69, nothing aftermarket here.
Old 03-23-2009, 10:03 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I agree with the other responses. Total timing of about 34 to 36 is common standard for the 454. The ZZ454 dyno test that SuperChevy did a few months ago stated they had their timing at 34. I have a ZZ454 and I run at 36.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 03-24-2009, 10:13 AM
g356gear's Avatar
Thanks for the input guys.
Old 03-24-2009, 02:53 PM
V8TV's Avatar
V8TV V8TV is offline
What heads are you running?
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
