Old 05-18-2009, 08:20 AM
Hotchkis Hotchkis is offline
senior member
Default New Hotchkis Mopar Subframe Connectors
[CENTER]
MAKE YOUR B-BODY LAUNCH HARDER & HANDLE BETTER
New Hotchkis Performance Subframe Connectors
For 1966-70 Chrysler B-Body Muscle Cars
Benefits
* Connects front subframe to rear chassis frame rail for maximum rigidity.
* Dramatically reduces chassis flex during hard cornering and acceleration.
* Improves vehicle handling, acceleration and traction.
* Tucked-in design gives excellent ground clearance.
Key Points
* Does not require cutting or modifying the floor.
* CAD Designed & Track Tested
* MIG Welded 1.5” x 2.5” .120 wall rectangular steel.
When it comes to setting up their cars, drag racers, road racers, auto cross competitors and high performance street drivers all share one common truth: increased traction and enhanced chassis rigidity improve overall performance. Now you can dramatically improve Charger, Road Runner, GTX or other B-Body chassis rigidity and improve overall vehicle performance with new Subframe Connectors from Hotchkis Performance.
Designed to rigidly connect the front subframe to the rear chassis frame rail, Hotchkis Subframe Connectors dramatically reduce chassis flex during hard cornering and acceleration, improving traction and overall handling. They are CAD designed to tuck up close to the floorboards for a strong yet stealthy low-profile fit that provides excellent ground clearance. Each kit includes two fully-MIG welded subframe connectors fabricated from 1.5” x 2.5” .120 wall rectangular steel that are powdercoated gloss black plus all necessary installation hardware. Installation does not require any modifications or cutting.
To preview the entire line of Hotchkis Sport Suspension parts and components, please visit www.Hotchkis.net, email [email protected], or contact Hotchkis Performance, 12035 Burke Street Suite 13, Santa Fe Springs, CA 90670, 877-4-NOROLL, 877-466-7655.
